Help needed in gas cap disassembly
cyaford
Nashville, TN
I've got the whole damn thing taken apart except for the pin on the base. It's the piece with the metal spring. It looks like I have to pop the end of the spring out that is in the pin. Any idea?
Here's a pic of what I'm referring to:
VIPER 93
Very difficult to repair. sent mine to arrow to be fixed
You can hammer it out with a smaller pin
C
cyaford
Nashville, TN
From looking at it, it appears a dental pick or something similar should be able to hook into the spring and free it from the pin. Putting the end of the spring back into the pin will be the fun part. :D
I'll try to take some pics of everything all taken apart, if I remember to bring my camera. As shown above, my camera phone *****. :(
C
cyaford
Nashville, TN
I talked to the Viper Wizard and he said the same thing that Viper 93 said. Hammer it out with a punch.
3 seconds after putting it in a vice, and it was out.
I'm guessing the whole assembly can be taken apart in less than a minute AFTER you do it the first time. :D
99 R/T 10
Enterprise, AL USA
What about putting it back together? I took mine apart and now can't find the small pin, only have a big one:
Anybody know where I can get a small pin?
97GTS
Winter Haven, Florida
Say it ain't so Mike!! You need a part and you DON'T have it?
The world is coming to an end, I can feel it.
:omg:
Ron
ACR2000GTS
Monroe, NC (Charlotte)
Just went through with this about 2 months ago. The way the cap is made the pastic pin that holds everything together on the latch is heat pressed/formed on either end. There should be a round end and a square end.
1. On the rounded end take a small razor blade and slice the end of plastic. This will allow the pin to slide through.
2. Take a phillips head screw driver and tap the round end pin through. This will allow you to take the latch off the base of the cap.
3. Reverse the same process to get it all back together.
4. Getting it all back together did not go that quick. If your taking it apart to get it chromed take your time putting it back together.
5. I reccommend using blue painters tape to cover everything to avoid scracthing it.
If you have any other questions or need some pictures let me know and I can send them.
01ACR/VIPER
ORLANDO
I used polished stainless socket head bolts to reassemble mine.
naimsito
