Help! Really need driver front tire or wheel for 08 coupe
Lucid
Love the new weather here in nepa hate the roads. Must have been *** hole that put a slow leak in the side wall.
I got 1400 miles on the car so 80+% tread is fine
If you have a rims or full set set I'm interested in those as well
L
Lucid
Forgot to add it's the oem tire I believe it's 275/35 maybe it's 295 have to check
love The New Weather Here In Nepa Hate The Roads. Must Have Been *** Hole That Put A Slow Leak In The Side Wall. I Got 1400 Miles On The Car So 80+% Tread Is Fine. If You Have A Rims Or Full Set Set I'm Interested In Those As Well
Danger Will Robinson!
Please buy 2 new front tires..... or measure the ACTUAL tread on the used one, and we will SHAVE a single tire to match that tripl-measured tread depth. WHY?
Becasue if you simply slap a thinner-thicker treaded front tire on there than the opposite side, you are creating a "stagger" that will drift low when crusiing, and pull the car to the low side on braking, or worse in an emergency.
That is OK on your fathers Oldsmobile, but NOT OK on a race-car chassis.
Why do you seek a wheel? If the wheel is NEW-LEAKING it is under warrantee!! (unless road-damaged).
You can call for more. BE CAREFUL!
