How Hot is your Temp Running?
byron69
Albuquerque NM
Just curious how hot your Viper is running at what temperature and location.
We average 96 degrees (high) @ 5000ft altitude in Albuquerque NM hit 225 on temp gauge.
Freddog11
Higley AZ
After I had the water pump and thermostat replaced about 2 months ago, it hasn't gone much above 200...and that's with 114 degree temps and the ac on.
pocketAA
Allentown, PA
I have a 99 Viper RT/10. I hear everyone on hear talking about 200 for a temp when the car is running. My temp guage looks as follows:
40 - - | - - 80 - - | - - 120
My guage doesn't even go up to 200, am I missing something here?
Anyway, my car ussually runs a little past the 80 mark on the above scale.
G
grcforce327
Guest
Post a pic of the gauge you're looking at!
V10SpeedLuvr
That can't be your temp gauge, can it?:dunno: I was thinking maybe its your oil pressure gauge, but mine shows 0---40---80. I usually run 55-60 psi when driving and 35 psi at idle since I replaced the oil cooler and lines. As for temp, mine doesnt get above the 3rd hash mark in the center...well, maybe a millimeter or 2 past it sometimes
99 R/T 10
Enterprise, AL USA
Pocket, you might have a Canadian car where it would read in C and not F. My bet and 100 C is 212 F. So if you're running 80 C, probably 175 F or so.
B
byron69
Albuquerque NM
What year is your car? Some of the 2000-2001 cars had defective waterpumps, but really 225 is not uncommon.
1998 GTS
K&N's, smooth tubes, belanger headers, r/t cats, corsa cat-back.
Everyone tells me these cars run hot and it is normal. I believe these cars are not all running hot that is why I posted the question.
We also might benefit from hearing what others have done to keep their cars running cooler.
Any upgrades to make the car run cooler??
Steve 00RT/10
Michigan
The Roe 170 degree Thermostat works WONDERS :D
I'll second that! Our supercharged car runs about a needle width above the little mark downstream from the 3 bold marks in the 190 area. That's in 6th gear, 60-75 MPH, and up to 85-90F. In 6th gear, no matter the temp, and up to 80-85 MPH cruisng speed, it never gets to the first bold mark. Even on the track a few weeks ago at 90F, I didn't get above the first mark after the 3 bold ones. ....Mostly ran between the far right bold mark and the next one up. Before the cool down lap was done, I was back on the bottom of the 3 bold ones.
Steve
Disturbed
Orlando, FL
I've got a Ron Davis Radiator and a Roe 180 F Thermostat. Even with the weather as hot as it is here in Orlando and the times I do a burst from 50-150mph, it NEVER gets above 200. It just say SUPER cool.
Now, if my headers would stay that cool....
svensk
New Mexico
Hi I drive an 01 ACR in Albuquerque with the following mods Roe Fan 180? Thermostat and aluminum radiator. Temps are 190- 200 cruising and maybe 210 in stop and go
Svensk/Huggorm
98viperGTS
South Carolina
I just posted this topic. Oops Here is the range that I am running is this normal?
pocketAA
Allentown, PA
So if I do have a canadian car, how hard is it to change out the temp gauge and replace with a US gauge? The car was imported to the US from what I recall from the copy of the carfax report, I asked the orig owner about it and he said he had no clue. It was imported from a canadian dealership to a US dealership here in the states when new. My gauge definitely does not look like the gauge in the post above....my gauge does read as follows:
40 | | 80 | | 100
what is a safe temp reading for my gauge?
z76232
That's exactly where my 97GTS runs. Phoenix 110 degrees.
Dave
Boxer12
Colorado High Country
My car runs 195-200F. There is a kit you can buy that track guys in Cali, Texas, etc., use, and it involves cutting a hole in the clip and directing air stream on the bottom of the engine. I hear it works great, but haven't had to use it. I think it runs a couple hundred bucks.
GTS Bruce
Orchard Park,NY,USA
Vented cowl,180 deg t-stat,DC computer tune to turn on fans sooner.Usual temp slightly below the left of middle hash mark.Stop and go traffic bring it to the middle mark.Oh acr oil filter adaptor too.(Cooler flows all the time and doesn't cut out at idle) GTS Bruce
big-n-italian
Central Illinois
can we see a pic of your vented cowl?
97gtsmonster
tampa fl
mine never goes over 200 here in florida. even in stop and go traffic. i have a fluidine radiator and the bigger fan with water wetter
mach4444
Naples florida
2000 RT/10 in SW Florida. My readings are exactly the same as your pic. never goes any higher even during 93 degrees and ****** conditions, with ac on of course.
ViperVon
Motor City
40 | | 80 | | 100
Between 80 and 100 on your gauge, which is between 176 and 212 in Fahrenheit.
GTS Bruce
Orchard Park,NY,USA
Vented cowl made by autoform through jon b.Came painted to match the car.Sorry not smart enough to figure out how to post pics.Looks stock.Must reuse weatherstrip between cowl and window.Vented area brushed aluminum grill. Bruce
big-n-italian
Central Illinois
if you can email the pic i would be happy to post it for you. there may be others who like to see it too. LMK.
No members online now.
ctrengine
