Darth Menace
Now that I have everyone's attention, I was wondering how to fix this. (the picture makes it look worse then it is, but I still want to straighten it up)
Ya i thought of that but unfortunately the rivets wouuld be showing,...so i was trying to find other options too.If you can get a piece of thin sheetmetal behind it you could create a doubler and attach it with rivets.
105 views in a bit over an hour.....need I say morelol great thread title thank you
Is there adhesive that takes the high heat?I don't know how much room you have, but you could also make "shims" and attach them with an adhesive.
that looks too rich for my blood. Has anyone ever had this problem or is it just meWhat hole?
Damn. That's a floppy hole you got there.[/QUOTE
I became an A hole
hahaha, but seriously are these exhaust holes prone to warping or is it just mineMy hole is not sagging at all, it's a b... h getting old.![]()
On a more serious note my rear exhaust opening aka hole is fine. So is my friends holes that I have checked. Your hole is definitely isn't right.hahaha, but seriously are these exhaust holes prone to warping or is it just mine
I dont mind them picking on it, it's when they start to poke their fingers in itMod the engine to the point where you need a parachute to slow the car down. Run parachute through hole. That will stop people from picking on your sagging hole.
shoot...earlier last summer i ran a couple days with no tips....maybe the heat did that. I was thinking of heating it up again and seeing if it would push bank into placeOn a more serious note my rear exhaust opening aka hole is fine. So is my friends holes that I have checked. Your hole is definitely isn't right.![]()
I guess that`s what happens when two hot rods have been stuck in it for 15 years
they were factory until this last summer when i went with straight-pipes there. Magnaflow is in there now, but that hole was messed before the magnaflowsWhat exhaust was in there? Factory or aftermarket?
on the inside as support, or the outside?My car has a metal trim insert on it. But I am not sure who makes it. It was on the car when I bought it.
