Ignition Timing maps to share
ViperGMC
TN
Been fine tuning and wanted to compare timing maps. Does anyone have a map that they would like to share? It's for my 04 SRT with high boost.
V
ViperGMC
TN
yep AEM, but timing advance is timing advance so it doesn't really matter. Any map will do. Just want to see what others are advancing at different loads and RPM
repiv
I will send you my aem files, have to DL them first. I am only running a low boost map at the moment, 5.5 lbs
V
ViperGMC
TN
That would be great! Do you have the traction control set up on your TT? I haven't played around with that much yet but i would like to.
repiv
No, I haven't set up the traction control. I am installing a Motec EMS next week(taking off the AEM), will use the tracton control with that system.
SKY1960
