varanus
Has anyone ever measureed the inlet air temp thru here? My viper tech did a rain baffle delete and covered the hole with metal sheeting. Since the airbox is right above the radiator where the metal was installed, it seems to super heat the inlet air. At Idle on a 60 degree evening I put a thermometer in the NACA duct and the air temp was over 140 degrees. I am not sure how having the car move at speed affects this, but it still seems awfully hot to a point of taking out power. As i remember every 10 degrees of ccoler air means 1 percent more hp. So 80 degrees would be 8 percent of 600 hp = 48 hp.
I am thinking of putting up a thermo insultion on the bottom of the airbox. Any thoughts on this?
