Is there a way to get under this panel?
0209 CLK
Northern California
Well I need to get a nut and bolt through this panel to install my roll bar and was wondering what ways can I get under it to install the nut to the bolt? Sorry if I'm not clear enough about this but I hope some of you may understand what I'm trying to say :confused: Here's a photo....
0209 CLK
Northern California
Yes behind the seat. I'm not trying to get it through the hole that is already shown, but to drill other holes on that panel to put a nut and bolt through it. I just can't seem to find a way to get under that panel..
Tom F&L GoR
Wappingers Falls
I think you are SOL, since that is above the gas tank area. In an RT, you have to remove the trunk wall.
Also, that is thin, unreinforced sheet metal. At least the shoulder belt hole has a thicker washer and is only in shear. A roll bar will absorb loads in all directions (well, hopefully not.) Is this an aftermarket roll bar?
Warfang
California, East Bay
Are you fabricating your own? Aren't there many rollbars available for an rt that have been proven to work?
Mando9595
