Is there service schedule someone can get to me? Just hit 15k miles.
whip383
Clovis, CA
When i picked up my car, the guy never gave me the owner's manual. Anybody have a maintance schedule they can email me? Car just went over 15k miles. anything i really need to do?
thanks,
chan
[email protected]
ViperJoe
Virginia
I would baseline everything, then you KNOW what you got.
Tranny
Diff
Clutch fluid flush
Brake fluid flush
Coolant flush
Power steering fluid flush
Plugs
And of course an oil and filter change.
That should about do it?
What YEAR is the Viper ????...important as SOME of the fluid items are time dependent as well as milage/usage dependent.
Would personally change the coolant and power steering fluids,as wellas check/replace/service air filters.
STRONGLY suggest that you get Dodge Service Manual for YOUR year of Viper...and, if it is a 1996, there are TWO DIFFERENT manuals...one for the RT/10 ( LAST year for GenI) and one for GTS ( FIRST year for GenII).
ENJOY your new Ride !!!
W
whip383
Clovis, CA
so is it 10qts or 9qts for the '01's (oil Change). ive been told both.
thanks,
chan
It SHOULD be 10 for an 01...I usually add the last quart SLOWLY, fire it up, shut it down, recheck several times rather than overfill.
Don't know what chart that you received, but will be happy to fax you service schedules from Service Manual if you need/want same before your Manual arrives...just e-mail your fax number to me.
