jacking up my 94
tim bob
do i need to buy a low profile jack to raise up my car? to change the oil, grease it,clean it up??? thanks :dunno:
T
tim bob
were can i find one and is there anything else i need to know or are they all the same? thanks
V10SpeedLuvr
T
tim bob
thanks alot i do have a local harbor freight and will go tomorrow for $100 great invetment. :rock: thanks for the info
FastZilla
San Antonio, TX
I do - but there are 4 jack points under the side sills. The frame rails in the back are real easy to get at too.
T
tim bob
i also have a local autozone i will check out both stores and purchase the one i like best thanks
terminator02
Detroit Michigan
V10SpeedLuvr
james11
You have a free jack in your trunk. You can use that jack to get it to the point where you can get a real jack in. Otherwise, if you drive the front over some wood, you will likely be able to get your regular jack under the car.
isanti
Minnesota
^^^^ I'm with stupid. If I remeber I will drive onto some wood or else I will get out the stock jack and get it to a point where I can get a regular in. A buddy of mine bought a low profile jack from walmart for $50. I haven't checked into it though.
T
tim bob
i went to two auto zones either one stocked the jack. shot over to harbor freight not only did they have them they were on sale for $79. well i have go and clean under my now thanks for all feedback. timbob
V10SpeedLuvr
You bought jackstands as well, right? It is not safe to only rely on the jack to support the car. If the jack fails, the car falls and you become a grease stain :nono:
T
tim bob
do i jack it up with the floor jack in 4 spots just behind the front tire put a stand than opposite side than just in front of rear tires????? as shown in fig 2 above. all confused
2snakes4us
Nixa , MO
jack in in the middle front as show with jack , place jack stands on each side to balance. then do rear. is that what your asking?
T
tim bob
yes thats what i was asking i got the right jack from harbor freight but its still not low enough to fit under the car i feel like an idoit....
R
RTED
Guest
Place a couple of one foot long 2" x 12" pieces of wood in front of you tires and drive the car on top of the wood and stop. You should have plenty of extra clearance.:2tu:
eucharistos
Houston
check the height of stands, may not fit where you plan on putting them
the frames are so stiff on these cars, you can lift an entire side just by jacking at 1 of the jack points
jack one side, place stand, then the jack the other side, or go to a center jack point lift then place 2nd stand
give it a try, will make sense once you start
peace
p.s. you bought the right jack, to reach the center you need a long and low jack, or drive up on 2x12's 1st
rlamorte
