Lenco Trans
Viper Grenade
Anyone ever use one with the air shifter. Can the air be adjusted for a soft easy shift...then to a super fast shift. I have a chance to buy a 4-sp lenco with a gear vendors under/over drive. I want to know what everyone thinks of these Lenco's as I don't know much about them but they can take 1000hp easy.
thompsonracing
Chalfont, PA
We've run one for years with both a Bruno and a Clutch. They are fantastic transmissions. We don't adjust the air and you shouldn't be worried about smooth shifting, you're going WOT for a 1/8 or 1/4 mile, transition should be smooth. There are a few tricks you can do inside the pucks, but you'll have to figure them out yourself. They are easy to service and easy to add or remove a gear.
What module do you plan to use to control the shifts? Timed based? RPM based? There are a ton of options. What is the setup you are putting it in?
