Lighter not working, fuse is OK ... change out the lighter base? ---
alwayscode390
STL
The lighter isnt working in either my or my buddies cars.
The fuses are ok ... is it common that the base needs to be replaced?
If so, what are the part numbers for a base ... or should I just get one from Auto Zone that matches up ... these are the DEEP socket versions, correct?
A
alwayscode390
STL
Yessir , it was supposed to be 15amp and was replaced with a 25amp though ---
ViperTony
Dumb question as you may have already checked for this but....are you certain that both wires are connected to the base of the lighter? My black wire came loose when I removed the console cover and I didn't notice it until the lighter didn't work anymore.
A
alwayscode390
STL
We checked to make sure it was all plugged in, I didnt inspect the wires closely though ... was your wire all the way disconnected, or just loose at the plug? ---
ViperTony
Mine was disconnected. I wonder if, perhaps, the contacts for the wire connectors have become oxidized?
A
alwayscode390
STL
They might be, my stock rivets around the shifter were turning white.
The window motors work great though from the switches by the lighter, maybe because they are used more? ---
xeng yang
