looking for a better power steering pulley
maxdaddy
louisville ky
Hi guy, my 2000 gts was just running in the driveway and the power steering pulley broke and flung the belt. The pulley is a cheap plastic one(I found one on ebay for under 20 bucks) ,but was wondering if there were any better ones? metal ? Thanks
LifeIsGood
Viper Lane, Arizona
There are numerous threads on this topic. You'll find that the vast majority of guys go with the billet aluminum power steering pulley and bracket made by Mark at IPSCO.
Grisoman
I glad this happened in your driveway . . . the gods were with you. I went the IPSCO pulley/bracket route that has a unique pulley hub that does not require a press-fit and assures the pump shaft does not shift in its bearings. Your toughest job will be removing the metal hub from your pump shaft.
Brian R
