wastntim
Couple of quick of stupid questions. What is best to use to lube door hinges? Any good way to apply to get into the hinges?
Take off the little body panel in front of the door. Three little bolts I believe (maybe 4). Make sure to note location and save all shims. put little dab of grease where moving hinge part contacts spring (you will see when you open/close door. Done.
