jcaspar1
I just finished installing a StopTech big brake setup on my 97 GTS and got a chance to use my Motive Brake Bleeder. Works great, much better than the old pump the pedal method. You can watch the fluid leave the caliper to be sure it is clean of any air and a single charge of 15 psi was plenty to completely refill and bleed each front caliper. Price is great and it can be used with nearly any car with the proper adapters. Seems to be a big improvement over the two man technique or speed bleeders. You can fill the reservoir with brake fluid so you can bleed all 4 wheels without having to refill the master cylinder. Customer service is great too as I originally loaned it to a friend and upon return the gauge was not working. I called Motive and the immediately sent me a new gauge, no questions asked, no need for a receipt or any proof of purchase.
Great product. Give it a try if you bleed your brakes with any regularity.
