Moton Canister Pressure
INSOMNIAC
Europe
What is the proper pressure setup for Moton canisters?
Are they the same psi for front and rear?
Thanks.
Nader
New York
There is no such thing as the proper pressure. it is adjustable for a reason. The more pressure you add, the firmer the suspension and vice versa. it is completely up to you. That is the beauty of the adjustability. With that said I run mine at 185 at all four corners. It is tight but not too much. The ride is great and it handles amazing.
Pressure in the cannisters acts like dialing in the spring rate in either direction.
Check the thread above for details...
Omaha NE.
The pressures are adjustable for a reason yes, and the increased pressure will help compression dampening BUT will lessen the rebound dampening. That said you will need to adjust pressure based on what you want/need more of when filling them or changing springs.
If you go stiff springs I would go a little lower pressure to control he rebound action better because you won't need the shock to act as a spring helper (bad idea anyway).
Hope this helps.
