Motul Fluids
SilverViperGTS
Montreal, Canada
Do you know if there are any drawbacks if I use top-of-the-line Motul fluids for:
1. Engine
2. Brakes
3. Tranny
4. Other parts ?
Thanks for your advice!
P.S. I'll be on the track in one month.
SilverViperGTS
Montreal, Canada
But Mobil-1 is not a real synthetic oil anymore. Do you think that using a real synthetic oil (with the Mopar filter) will be harmful for the engine?
95Viper
Phoenix
I do the same as slaughterj. Motul brake/clutch, Mopar fluids for trans/diff/power steering, Mobil1 oil.
They make Vipers with Mobil1 today so I'm sticking with it.
Tiepilot
Lilburn, GA
FYI, The Mopar Oil filter is made by Mobil-1 and no you can't harm the engine by using the correct grade synthetic or blended oil.
jcaspar1
Sacramento, CA
Why use Motil for the clutch? Does't seem like a high wet boiling point is needed for the clutch. I use Motil 600 RBF for brakes and Valvoline Synthetic for clutch.
ChrisGTS
Atlanta, GA, USA
One thing to keep in mind when using Motul brake fluid is that I believe it absorbs water more quickly than more conventional DOT-4 fluids with a lower boiling point. This means that, if you use it, you would need to change it more frequently.
95Viper
Phoenix
I use it for the clutch because I'm still a rookie brake bleeder even with the Motive Bleeder and I always end up with extra fluid left over so I use it in the clutch.
I was told Motul does not absorb water more quickly than conventional DOT4 fluids.
zeeshan_k24
