My 08 has check engine light but not codes!
weightlifter123
The check engine light came on. Car runs fine. Went to Autozone and hooked an OBDII scanner to it and no codes came up. Tried another friends OBDII scanner and no codes come up either. What could cause the check engine light to come on and no code come up in a scanner?
VENUM INJECTION
Mississippi
I had the same prob on my new 08. Although my gas cap was on tight, they said if you got the edge wet at all it might not seel and that light would come on. Car ran fine, they dried off the cap and put it back on and light went off. Goodluck.
Roadrunner
Make sure you are using a scan tool that is compatible with 2008 CAN standards... the older code scanners will not support the Viper PCM.
I would hope "autozone" scanners would have latest software, but there is no way to be sure.
SKY1960
