My Auto Meter Shift Light is not working.......help?
SRTim
Pittsburgh, PA, USA
When my tachometer reaches the rpm that the shift light should come on, the tach just bounces up and down-and the light doesn't light up.
When I remove the pill that tells it when to shift, the tach works fine.
Any suggestions on how to fix it?
Thanks,
Tim
jcaspar1
Sacramento, CA
I finally got mine working. I installed a Armtech light per the instructions in the cookbook but was having problems with stability of the triggering rpm. I switched the trigger wire from the one recommended in the cookbook (Coil #1) to the tach lead (thanks Tom) and all is well now.
SRTim
Pittsburgh, PA, USA
Sheyster-I have tried all the different pills-and that just makes the tach stop working at whatever rpm the pill is set for.
Mike H-Yes, the shift light was calibrated for a 10 cylinder. It worked fine for about 4 months-it just started this about 2 weeks ago.
Thanks,
Tim
cs83
