Need Headers. Help me decide
ACPERFORMANCE
Murrieta CA
We just added Matt's M&M Headers to a bone stock 2004 Viper. We also added some high flow metal substrate cats, corsa track exhaust and retuned the car. It picked up 52 rwhp in total. M&M Headers fit, and they make power. And Matt's service is second to none.
Todd
A&C Performance
VicTxV10
Victoria, TX
I found this You Tube clip of an 09 with M&M headers. There was no posted hp gains, but it does sound good.
[media]http://www.youtube.com/watch?v=6K1jt143ddw&feature=player_embedded[/media]
Catwood
What's the torque gain on a stock '09 for M&M or Belanger header over the RPM range? Any dyno graphs for comparison.
Todd...did you want so send me some graphics for the Coronado event?
VicTxV10
Victoria, TX
Found the dyno sheet for the 09 in the video clip.
2009 Dodge Viper M&M headers Dyno Dynamometer Results Graph
Horsepower: 585.61 HP
Torque: 565.27 ft-lbs
VicTxV10
Victoria, TX
Says the drivers name for the 09 in video is Viperless. I wonder if it is Keith on here,a.k.a. Viperless. He has an 09 graphite coupe just like the one in the clip.
viperbilliam
Richland, WA
I have kooks. I made a post about them a couple years ago. I like them a lot. The car made 494hp 522tq at the wheels with just the headers, no cats and a corsa....and it sounds mean!
I should have had them coated to cut down on the heat. Some of the flex loom on some wiring has melted, though I have seen the same thing on cars with belangers too which are coated.
Kooks angles the down stream o2 sensor to make more room to help reduce the chance of melting the wires.
Kooks headers are a 5 into 1 witha nice merge collecter and they are one peice so installation is very difficult compared to the other multi piece headers.....never had a leak though.
+1 - I didn't notice any wire melt problems - factory header insulator was retained. Do be aware of resonance problems though.
LifeIsGood
Viper Lane, Arizona
I wasn't able to find the 'hypercoat extreme' ceramic coating on the site that you listed. Do I need to call them to get information on the product? Is it a spray paint or do the parts need to be dipped? Did it change the color of your headers? Do you still need/use heat shields for your headers?
A couple of things about headers:
Not long after header install, you will notice that your gear shift suddenly becomes VERY hard to get into reverse, and overall gear shifting is difficult. This is because your wiring on the O2 sensor has gotten too close to the headers, the insulation melted, and there is a short, which blows the same fuse that your gear shift reverse lock-out solinoid uses. I can't keep track of the number of times this has happened to people. So, make sure that you insulate the wiring near the headers with heat resistant materials.
On a similar vein, I would highly recommend heat coating on your headers. I used a ceramic coating from HPC called "hypercoat extreme" I was truly amazed at the difference it made in keeping my headers (and engine compartment) cool.
http://www.hpcoatings.com/default.aspx
Cape Coral, FL
If interested, I have a set of B&B Stepped Headers [and a B&B Cat-Back as well] that are used, and can cut a NICE deal on.
KaiPL
Salt Lake City
Here is the link to the hypercoat extreme page:
High Performance Coatings, Inc.
Call them. This is not a spray paint, the parts have to be dipped at their shop. You ship the headers to them, they coat them, and send them back. Takes about a week.
The coating is available in black or grey. I chose black, and I think it looks good.
I do not need heat shields for my headers after the coatings. Prior to the coating, I needed heat shields. I had the headers removed, coated, and replaced, and I ditched the heat shields. The headers never get as hot as they did before. This is one of the few products that worked better than I expected.
Viperless
MN
That's me. :D
Here are a few videos from last Monday. Finally got the '09 on the track. First two are in car, third is outside. You can get a pretty good idea how the car sounds.
[media]http://www.youtube.com/watch?v=f7FDMGnqUtI[/media]
[media]http://www.youtube.com/watch?v=WOsUFS7kfYg[/media]
[media]http://www.youtube.com/watch?v=-PS0BBpsHUs[/media]
bmw2nv2000
Adamsville, TN
I just sent an email to High Performacne Coatings about coating some M&M's for me. Does anyone hear know the cost for coating?
ILLSMOQ
SAN JOSE, CA
m&m headers come coated...why do yours need to be recoated?
I had a local place do a set of headers and a complete flowmaster 3" exhaust system for a 66 GTO (lots of pipe) a few years ago set me back about 500 bucks...definatly worth it.
Lundqvist
wait iv seena few people in this thread say you dont gain any HP from headers for a gen 3..
im confused. then why spend 3k on parts and installation for something that gives no gain?
Twister
NO BETTER WAY THAN TO LOOK AT THIS LIST OF WHAT PEOPLE DYNOED WITH WHAT
made a couple of revisions as of 6JULY2010
NAME-Steve B
YEAR-2003
RWHP/RWT-534/557
TYPE DYNO-Dyno Dynamics
MODIFICATIONS-KN filters...American raceing headers...Corsa exhaust...A&C SCT tune
[media]http://www.youtube.com/watch?v=wZRzAwFqOy8&playnext_from=TL&videos=xaBtHBk8JzY[/media]
NAME-Dipapa
YEAR-2005
RWHP/RWT-521/538
MODIFICATIONS-KN intake...headers...no cats...VEC3 tune...67mm throttle body...light weight flywheel
NAME-Dimitrios
YEAR-2005
RWHP/RWT-513/569
TYPE DYNO-Mustang
MODIFICATIONS-Ab's quality wires...3" Corsa...no cats...K&N Cold Air...ROE SCT Flash
NAME-Copperhead245 "Ron R"
YEAR-2005
RWHP/RWT-508/522
TYPE DYNO-Mustang
MODIFICATIONS-Kn filters...x metal throttle body...autolite XP985 spark plugs...Big Brakes Daves under drive pulley...corsa exhaust...SCT tune
NAME-MikeR
YEAR-2005
RWHP/RWT-508/522
TYPE DYNO-???
MODIFICATIONS-green filters...m&M headers...Corsa exhaust...no cats..Big brakes Daves under drive pulley...X metal throttle body...DC tune...XP985 spark plugs
NAME-Bandit3
YEAR-????
RWHP/RWT-507/???
TYPE DYNO-???
MODIFICATIONS-Bellangers...3 inch pipes...no cats...Roe SCT tune...Roe single plate throttle body...K & N air filters
NAME-Gonabite
YEAR-2006
RWHP/RWT-499/550
TYPE DYNO-Dyno Jet
MODIFICATIONS-American raceing headers..High flow cats...B&B cat back exhaust...SCT tune
NAME-Shandon
YEAR-2005
RWHP/RWT-492/517
TYPE DYNO-???
MODIFICATIONS-Balanger Headers...Corsa exhaust...No cats...BBK throttle body...KN filters...AB wires...Chromoly Flywheel...VEC3 tune
NAME-Trymyz
YEAR-2005
RWHP/RWT-491/485
TYPE DYNO-Dyno Jet
MODIFICATIONS-No cats...KN intake...VEC3 tune
NAME-Dragon rider
YEAR-2003
RWHP/RWT-490/525
TYPE DYNO-???
MODIFICATIONS-corsa exhaust...high flow cats...KN intake...sct tune
NAME-Flyntgr
YEAR-2005
RWHP/RWT-490/525
TYPE DYNO-???
MODIFICATIONS-Green filters...Headers...cat back exhaust...high flow cats...VEC3 tune...170 degree thermostat
NAME-Reggie
YEAR-???
RWHP/RWT-490/523
TYPE DYNO-Dyno Jet
MODIFICATIONS-KN filters...headers...cat back exhaust...VEC3 tune
NAME-Vinny2
YEAR-2006
RWHP/RWT-482/520
TYPE DYNO-Dyno Jet
MODIFICATIONS-KN intake...Mopar exhaust...VEC3 tune
NAME-Nader
YEAR-2004
RWHP/RWT-482/511
TYPE DYNO-Mustang
MODIFICATIONS-corsa exhaust...single blade throttle body...KN filters...DC tune
NAME-Viper Specialty
YEAR-2004
RWHP/RWT-480/520
TYPE DYNO-???
MODIFICATIONS-corsa exhaust...high flow cats...Vec2 tune...RC1DECC spark plugs
NAME-Yelloh
YEAR-2005
RWHP/RWT-479/528
TYPE DYNO-???
MODIFICATIONS-Bellanger headers...high flow cats...SCT tune
NAME-Twister
YEAR-2003
RWHP/RWT-476/512 SAE...491/529 STANDARD
TYPE DYNO-Dyno Jet
MODIFICATIONS-KN intake...Arrow roller rockers...no cats...titanium exhaust...Findanza light weight fly wheel...Big brake Dave's underdrive crank pulley...Viper Specialty SCT tune
NAME-GripforceSRT10
YEAR-2005
RWHP/RWT-475/???
TYPE DYNO-???
MODIFICATIONS-corsa exhaust...high flow cats...findanza light weight fly wheel...170 degree thermostat...DC tune
NAME-Mark Guolinos
YEAR-2006
RWHP/RWT-472/479
TYPE DYNO-Super Flow
MODIFICATIONS-American raceing headers...high flow cats...corsa exhaust...SCT tune
NAME-BlueBatmobile
YEAR-2006
RWHP/RWT-470/514
TYPE DYNO-???
NAME-B767Driver
YEAR-2006
RWHP/RWT-470/477
TYPE DYNO-???
MODIFICATIONS-Bellanger headers...KN intake...no cats...cat back exhaust
NAME-1dumpedviper
YEAR-???
RWHP/RWT-461/480
TYPE DYNO-Dyno Jet
MODIFICATIONS-comp coupe exhaust...dc tune...170 degree thermostat
NAME-Pteam
YEAR-2005
RWHP/RWT-460/497
TYPE DYNO-Dyno Jet
MODIFICATIONS-KN intake...corsa exhaust
NAME-Ibstone
YEAR-2005
RWHP/RWT-460/470
MODIFICATIONS-Bellanger headers...high flow cats...cat back exhaust...3.73 gears...SCT tune
NAME-Dman
YEAR-2003
RWHP/RWT-456/487
TYPE DYNO-???
MODIFICATIONS-KN intake...Corsa exhaust
NAME-Texas venom
YEAR-2004
RWHP/RWT-454/474
TYPE DYNO-???
NAME-Canyon707
YEAR-2004
RWHP/RWT-443/465
TYPE DYNO-???
Twister
HERES MY UNDERSTANDING FOR HEADERS ON THE GEN3'S
B AND B STEPPED HEADERS ARE WORTH 5-10 RWHP
BELANGERS ARE WORTH 10-15 RWHP
M AND M'S ARE WORTH 10-15 RWHP
AMERICAN RACEING HEADERS ARE WORTH 15-20 RWHP
The gen3's just dont pick up a whole lot...But 15 rwhp from some american raceing headers is the route Im personally going..
The fact is that if you want to hit the 500 rwhp mark then you pretty much have to get headers on your gen3
KNG SNKE
Portsmouth, Rhode Island
I run M&M headers and they really make the exhaust sound good. I do have a Roe so my tone is different but I will say I had the Roe with stock manifolds and when I added the headers it brought it down a couple of tones.
ViperGTS
Where do I get M+M headers? Chuck Tator?
EXHLR8N
Costa Mesa, CA
My advice is to call Dan Cragen at DC Performance. He has indepth experience in all these headers, which ones pass smog and which ones increase performance.
Best of luck.
cowger2
