jgrakla
Hello All, and thanks in advance for any help you can lend. I've got a problem with my Viper and the solution is not readily ovious to me even after reading several of the archived postings.
I have a 94 RT/10 and it has developed a coolant leak. I found coolant on the floor under the car and observed it dripping off the front facia. Also, if I start the car, coolant will start dripping pretty good. I have read several of the postings about the facia screws puncturing the overflow bottle. I have done the test of pouring water into the hose into the overflow bottle and no more leaked out. I removed the acces cover in the right front wheel well and have observed that the bottle is full. I don't mean normally full. I mean completely full. I can also see that the coolant has been leaking from that general vicinity but I cannot see the source of it.
I have checked all the visible lines and connections. The upper and lower radiator hoses are good. No leaks there. It is definitely concentrated in the front right behind the facia. I believe at this point I am going to have to remove the facia so that I can hopefully identify the source of the leak. But, before I do all that work I was hoping you could help me out.
At this point my current theory is that coolant is entering the overflow tank, but not leaving. That might explain why the overflow is full up. I assume the overflow bottle has both an inlet and an outlet. Maybe the outlet hose connector is clogged, or loose, or disconnected??? That might explain the leak.
I have several questions:
1. Pardon the pun, but does my theory above hold water?
2. If not, what other causes might there be?
3. If I do have to take the facia off, are there procedures already documented somewhere in the archives, or do you have any tips for me? Is it a difficult task to take the facia off?
4. If it turns out to be the radiator that is leaking, what is the current advice on whether to replace with a stock part or go after market?
Any help appreciated. Thanks,
Jason Graklanoff
'94 RT/10
Jason Graklanoff
'94 RT/10
