1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Need new shifter boot. Will that solve all heat problem?
Discussion in 'SRT10 and SRT10 Coupe Discussions' started by anton28, Sep 7, 2013.
  1. anton28
    anton28 Enthusiast
    37
    1,361
    Dec 22, 2005
    Theres A LOT of heat coming from the center consol. After enought time I can't even touch my shifter it's gets so hot. I know I've always had a ripped rubber shifter boot. Now that I got my car back from RSI It produces so much more heat so Im going to replace the rubber shifter boot but Im wondering if there is anything else I can do while I'm there to reduce the heat coming from the center consol.
  2. intense5.5
    intense5.5 Viper Owner
    446
    May 17, 2009
    Northern NJ
    To replace the inner rubber shift boot you'll have to remove the shift bezel and center console (did mine today - replaced the ripped inner boot and added a red stitched shift boot). Once the console is out you could try wrapping it in this; http://www.eastwood.com/dynaliner-1-4-12sq-ft-32-x-54.html
  3. Moundir
    Moundir Enthusiast
    1,816
    Oct 3, 2002
    Ny
    Transmittion cooler! Worth every penny! That heat is gonna kill your current transmission, better get I front of the problem.
  4. 98intrigue
    98intrigue Viper Owner
    34
    325
    Apr 11, 2012
    Clearwater, FL
    I have the same problem, Anton. Not sure if the boot was ripped before I got my car back, but it was all ripped up when I replaced my center console. After awhile, it's too hot to touch.
  5. anton28
    anton28 Enthusiast
    37
    1,361
    Dec 22, 2005
    Good point and i will definetly be looking in to this but that will not address the temp issue that im talking about.Which unit did you end up using?
  6. anton28
    anton28 Enthusiast
    37
    1,361
    Dec 22, 2005
    Have you replaced the boot yet?
  7. anton28
    anton28 Enthusiast
    37
    1,361
    Dec 22, 2005
    Did you notice a significant temp change when replacing just the boot?
  8. anton28
    anton28 Enthusiast
    37
    1,361
    Dec 22, 2005
    mhow about the dyniliner? Did that work well for you?
  9. Moundir
    Moundir Enthusiast
    1,816
    Oct 3, 2002
    Ny
    Dont know the brand, I got it from Donato Engineering. I came with my new rebuilt 6060.
  10. Stonep185
    Stonep185 Viper Owner
    140
    Nov 30, 2011
    Ft. Worth, TX
    My center consol/shifter heat was reduced by 30-40 degrees when I replaced fluid with amsoil 75w-90.
  11. intense5.5
    446
    May 17, 2009
    Northern NJ
    I just changed the boot and haven't spent much time in the car yet to tell. I didn't add any matting, I just knew what you were looking for.
  12. LifeIsGood
    LifeIsGood Enthusiast
    2,256
    Jun 1, 2008
    Littleton, CO
    I'm fairly certain that I've heard the metal ring around the GEN IV shifters get pretty dang hot. My GEN II lower radio bezel area gets hottest when there's a combination of spirited driving and a sunny day. I'm sure that a non-damaged lower shift boot will help, but it won't solve the issue.
  13. 98intrigue
    34
    325
    Apr 11, 2012
    Clearwater, FL
    Not yet. My car has been down for another 2 months.
  14. Sonoman
    Sonoman Viper Owner
    424
    Mar 10, 2011
    Sonoma Cownty
    The rubber inner boot on the shifter is paper thin and is intended to stop airflow but not heat that is conducted through the shift mech itself. So it will reduce the temp of the ring surrounding the leather boot on your console, but not the temp of the shift lever. I got good results lining the transmission tunnel under the car with self adhesive heat-reflecting aluminized insulation material. Found it on Amazon and it's only about 1/16" thick, cuts easily, and adheres well. Apparently, the new Corvette C7 is using the spaceage Aerogel for lining the transmission tunnel. This stuff is great but 3-4 times more expensive (we use it at my aerospace job).
  15. anton28
    anton28 Enthusiast
    37
    1,361
    Dec 22, 2005
    now what happened???
  16. anton28
    anton28 Enthusiast
    37
    1,361
    Dec 22, 2005
    great advice!
  17. Malu59RT
    Malu59RT Viper Owner
    1,279
    Oct 10, 2007
    Dallas, TX
    I noticed this on my Viper, and got my torn shift boot replaced under extended warranty, as it was burning my forearm driving around. After replacement, the temperature on the transmission tunnel was much better, hope this helps!
  18. ACRucrazy
    ACRucrazy Enthusiast
    1,894
    Jul 14, 2009
    Is there someone that sells a kit? Where can I read more about this?
  19. 98intrigue
    34
    325
    Apr 11, 2012
    Clearwater, FL
    Drove through standing water and hydroplaned into a guardrail. I seriously can't catch a break.
  20. anton28
    anton28 Enthusiast
    37
    1,361
    Dec 22, 2005
    Bro I'm sorry to hear that. Some cars just have gremlins bro. I'm not saying sell the viper for something else but maybe sell this one for another one.
Share This Page
