Need Tire help between Pirelli verses Michilins
YELLOH
Cape Cod, Mass
Question Pirelli P Zero tire better than the Michelin Pilot sport run flat .I have only driven Mich PS on autocross track and tires have gripped well.Mich PS I know have a thicker wall on the because it is a run flat tire .Do I get a better ride with the Pirelli tire,and does it handle well .Plus being a tire that is not a run flat tire,do you waste a rim if I should get a flat,and should I carry a can of Slime in the car at all times.Thank you for any input on this matter greatly appreciated.2005 SRT10 YELLOH
myfirstviper
south florida
sorry i cant be of much help. but from everything i've read, the stock run flats are [******]. and i have read that a few have said the pirelli is better.
i wish this post would get more real world feed back. i persoanlly am probably going to go down to an 18 inch rim and go with khumos.
but for sure without a run flat, if your tire blows in the middle of no where the fix a flat would probably come in handy.
hopefully some guys with real experience will reply to your post, as i am interested in the tire question myself.
mark1962
Cincinnati, Ohio
There was an article comparing several performance run-flat tires in Road and Track 2 or 3 months ago - you may be able to dig that up.
Nader
New York
I went with Pirelli p-zeros and a plus one combination HRE's 19's upfront and 20's in the rear. I must say it is a night and day difference. The new rim and tire package is much lighter than the stock set and the traction is greatly improved. You can definitely feel the improvement in ride quality.
DavidSB
Santa Barbara
TireRack sells a $75 kit made by Continental with a small 12v compressor and a can of sealer for non-runflats. There's a photo of it on the Tire forum here. I'd also carry a puncture/plug kit ($15) if you were lucky enough to get a puncture in the tread that could be plugged instead of having to use the sealer - and then when you get to a tire shop have a vulcanized patch put in behind the plug.
99 R/T 10
Enterprise, AL USA
I have a set of Pirelli's P-Zeros(335-25-19") for sale($550 plus shipping). The tires are new, still have the stickers on them if you want to give them a try. :2tu:
Y
YELLOH
Cape Cod, Mass
Thank you for the info that is exactly what I wanted to hear
Nader
New York
Make sure you properly inflat the pirellis. The runflats require on 28lbs due to the stiffer sidewall. I have my pirellis at 36lbs now and ride is perfect.
Y
YELLOH
Cape Cod, Mass
Thank you for that note.
miwr
