New Exhaust for my RT/10
95Viper
Phoenix
Do some searches for corrosion + sills and corrosion + rockers, good info here.
Caused by moisture trapped between insulation and sill. Heat from stock cat enhances the problem. Do not use stock cat, way too hot.
Call Roe Racing for cat replacement or go catless.
3snakes
hey car lover would you sell me the old ones need them for a thing that iam tring steve
3snakes
hi GRAIG i was looking for the rockers. think that is what he was talking about? thanks
STUGOTS
NY/CT
i have a set of perfect rockers off a 99 R/T im selling cuz i got 1.7 jesels for the car
ViperJoe
Virginia
Gen1 rockers and attaching hardware for nortorious for corrosion (I think due to the dis-similar metals reacting).
95Viper
Phoenix
Corrosion on the rockers is not bimetal corrosion. This was originally thought to be true but the rivits are aluminum as the rockers.
The corrosion is caused by moisture being sandwiched inside the rocker under the insulation. Takes days to dry out if you get that area all wet.
Heat from the stock cats just makes the problem worse and speeds up the corrosion.
Mando9595
