NEW Shiftlight Installation (Pics) - Anyone Interested in Group Buy? (w/Instructions!!!)
Achilles99
Atlanta, GA
First, my thanks go out to Steve-Indy for faxing me the appropriate wiring diagrams for the PCM. I just installed my new Raptor Shiftlight, and it works FLAWLESSLY. Originally, I was going to mount an autometer shift light, but I decided against it because:
1) Too big
2) Needed RPM pills
I also briefly considered the shiftlight drawn up in the illustrated upgrades. But, that one (VDO) required a separate brain to function correctly. The Raptor is about the size of a Lifesaver's roll, and is completely self-contained. It only needs three wire hookups (tach, power, ground), and is completely adjustable without pills or a separate controller. It also requires no modification to function with our V10's (unlike the Autometer, where you either have to adjust the wiring for V10's, or use staggered pills to simulate RPM's). I installed it in under an hour, and that included tucking the wires, etc. Here are a few pics. The LED's are SUPER BRIGHT. I wondered why they included a "night" cover. Now I know! The lights are so bright, that I might just leave the cover on during both day and night operation. They also included a "black" cover to block out all light. The pictures do NOT do the brightness levels justice. If you've ever looked at an LED flashlight before, you'll know what I mean. The supplier expressed interest in a group buy. Pricing would be lower than the $85 retail, depending on quantity. Finally... no Viper tax!
Here's the unit turned off, with no cover:
Turned off, with cover:
Turned on, without cover:
Turned on, with cover:
<font color="red">Added by Vipermad 2/8/05</font>
2001 Dodge Viper GTS Raptor Shiftlight Installation
(should be similar installation for 1992-2002 Vipers)
1) The package arrives nicely packed, and includes the shiftlight, two covers (one black, and one color matched to the LED color you choose), and a set of instructions.
2) Remove PCM cover on driver’s side, under the hood. It is held on by four 8mm bolts, and two regular Phillips head screws. Then, remove cover on leftmost plug (C1) by depressing black tabs.
3) From the inside of the car, velcro the shiftlight to the top of the steering column. Then, feed the wires to the fusebox by tucking it behind the dash panel (show below, with three screws removed in order to tuck wires).
4) At this point, cut a small 2-5 section of the conduit (do NOT cut wires in half… ONLY cut the conduit cover that is around the wires. A small knife may help.) that is located by the fusebox in order to expose the black ground wire and red power wire (do NOT cut the green wire at all… you will feed this through the firewall to the PCM). You can tap into the fusebox for power, and ground the black wire to one of those screws that are touching bare metal in the fuse panel (see above picture).
5) Next, locate the grommet located just in front of the drivers side windshield, under the hood. Guide a coat hanger through the hole and into the fusebox area. Tape the green wire (which should still be in the black conduit) to the coat hanger, and pull through the grommet in order to bring the conduit with green (tach) wire into the engine compartment.
6) You can either solder or use a wiretap to attach the green wire to one of the ignition coil wires on C1. On a 2001 GTS, Pin 1, 3, 5, 7, and 9 are all the coil wires. I used Pin 1, which is a yellow wire with gray stripe. If using a tap, try and install as low on the wire as possible, in order to have room to replace the plastic cover for C1. If you are unsure of which wire to tap into, please run a search on the VCA forums for clarification of the tach wire.
7) You’re done! On the shiftlight, set toggle switch 1 to OFF, 2 to OFF, and 3 to ON. This will put the shiftlight into 2-cylinder mode (which is appropriate for our V-10’s, since each coil powers two cylinders). Set RPM dials (first one is in thousands, second is in hundreds. Thus, to set at 5,000 RPM’s, set first dial at “5”, and second dial at “0”). Start car, rev engine and make sure that light functions before putting all the panels back together. Enjoy!
Comments from The Wizard: "wires at the PCM MUST BE soldered and use heat-shrink on your soldered connections!"
Simms
Pittsburgh, PA
Re: NEW Shiftlight Installation (Pics) - Anyone Interested in Group Buy?
Cool, it looks just like my High Tech Speed shift light.
A
Achilles99
Atlanta, GA
Yes, both the Raptor and High Tech look the same, except that the High Tech shiftlight requires a separate brain to install. This one is all self-contained, and is cheaper by $40 or so (and that's before the group buy discount).
Oh, and I'm not affiliated with Raptor Permance at all. I'm just happy to have found a cost effective solution that's easy to install, and looks great!
Here are the colors/lights available:
http://www.raptorperformance.com/
A
Achilles99
Atlanta, GA
Ricky, likey, please put me down for atleast "1"....does unit require tach driver?
Nope, no tach driver (I think you meant like a control unit, right?). This is a COMPLETELY self contained tube, and has a 10 foot long black wire (with 3 wires inside it... tach, power, ground) coming out of it. I tucked the wire from the steering column, to behind the dash, down to the fusebox, etc. I'll have a full writeup with installation pics soon. Who do I contact to get it posted under Illustrated Upgrades?
BLUESNAKE367
VIRGINIA BEACH, VIRGINIA
Sweet, put me down for "2" I will need one for my Ram SRT/10 also, Please make contact with Tony "VIPERMAD" for posting diagram, he will help out...
Qualitywires.com
Louisville, KY
I am interested...as long as install is simple.
A
Achilles99
Atlanta, GA
Sounds good. BTW, in case people were wondering, this unit is adjustable for any cylinder combination. It is virtually idiot-proof to setup. I had it running on my first try (I was a little hesitant, since most people have had issues with PCM wiring and shiftlights that aren't V10 compatible).
A
Achilles99
Atlanta, GA
I'll have them make up a special shiftlight for you AB, that requires minimal welding ;)
Hisserman
Waterford, MI
Achilles99 --
Glad to see you're happy with that new red ride!
Put me down for a Raptor shift light too. Let us know the details when you get ready to finalize the order.
Joseph Dell
Atlanta, GA 30338
Put me down for one as well. I'm ready to ditch tha autometer... I like it, but I want something a little different.
Put me down for it soon so I can order it up STAT. I'm axious... :)
JD
A
Achilles99
Atlanta, GA
Achilles99 --
Thanks again for helping me with the inspection ;)
So far, here's who I have ordering. If you want one, please add your name to the bottom of the list and repost.
Kurt K. (black/red)
BLUESNAKE367 (2 black/red)
HISSERMAN (black/red)
JERRYC (chrome/red)
AB (black/red)
I'm assuming that those who didn't indicate a color want the black w/ red LED's?
V10 ACR
San Diego, CA
Looks nice. Put me down for one as well. Thanks.
Kurt
A
Achilles99
Atlanta, GA
Kurt K. (black/red)
JERRYC (chrome/red)
AB (black/red)
JD (silver/red)
What does STAT stand for JD?
Joseph Dell
Atlanta, GA 30338
STAT = impatient. I got the car in pieces and am ready for final assembly... this would be the icing on the cake.
Maybe I want black, actually. The web site says that silver is back-ordered. If it is, I'll take black. otherwise, silver.
Thanks!
JD
ERDOC
Raleigh, NC
I guess I'll take one also.
A
Achilles99
Atlanta, GA
Kurt K. (black/red)
JERRYC (chrome/red)
AB (black/red)
JD (silver/red)
ERDOC (black/red)
Again, if you want to order, add your name to the bottom of the list and post (don't just make a post saying you want one... copy and past the above list, and add your name to the bottom. I've already done it for the people above this message). I'll get final pricing info together and let everyone know ASAP.
trainville
Oregon
Kurt K. (black/red)
JERRYC (chrome/red)
AB (black/red)
JD (silver/red)
ERDOC (black/red)
TRAINVILLE (black/red)
Thanks!
NICE JOB, Linh...agree that a writeup would be a great addition to the archives !!
Eric H
Raleigh, NC
I'm in. order me the same one you got.
Simms
Pittsburgh, PA
Thats awesome that it is all self contained.
mntngts99
Boise, ID, USA
Kurt K. (black/red)
JERRYC (chrome/red)
AB (black/red)
JD (silver/red)
ERDOC (black/red)
MNTNGTS99 (black/red)
IEATVETS
Cottage Grove, Wis.
Kurt K. (black/red)
JERRYC (chrome/red)
AB (black/red)
JD (silver/red)
ERDOC (black/red)
IEATVETS (black/red)
How do you set the shiftpoint with no pills?
Viper23
Kurt K. (black/red)
JERRYC (chrome/red)
AB (black/red)
JD (silver/red)
ERDOC (black/red)
If it works on a 96 R/T 10, I would like one in black/red light please.
dblankenbaker
Scottsdale, AZ
Kurt K. (black/red)
JERRYC (chrome/red)
AB (black/red)
JD (silver/red)
ERDOC (black/red)
DBLANKENBAKER (2 black/red)
A
Achilles99
Atlanta, GA
OK, what don't some of you get about adding your name to the bottom of the list, and not just posting "I want one"? I'll add Eric, Mark, Viper23, and VIPR GTS since they can't follow directions :)
VIPER23 - Shiftlight will work on any car... it's not vehicle specific (you just have different settings for each type of car cylinder).
IEATVETS - RPM selection is easy. There are two dials, one for the 1,000's digit, and one for the 100's digit. So, if you want 5,400 RPM's, you set the first dial to 5, and the second to 4.
Kurt K. (black/red)
JERRYC (chrome/red)
AB (black/red)
JD (silver/red)
ERDOC (black/red)
ERIC H (black/red)
Mark "Super Charged GTS" Cooper (black/red)
VIPER23 (black/red)
VIPR GTS (black/red)
