Movers let the battery run down on my 98. No problem, I'll just retrain the PCM, right? Nope.
I've done everything I can think of to get it to reset and be "READY" for DMV inspection:
Disconnect positive connections in engine bay battery post, pull off three large wire connectors from the PCM, let it sit for 30 min.
Then with key on, depress throttle all the way, twice.
Turn key off, start car and let idle for 3 minutes, drive around for a long time.
Cold start, drive 55 for 20 minutes (tough to do when the posted limit is 70!) etc etc.
I've hooked up the OBD many times and I'm "NOT READY". The car runs OK, but clearly the PCM isn't happy.
Am I missing some part of the routine?
