OBD / OBD II
bunkercowboy
Boerne, TX
This morning noticed at some point the OBD sensor came on. Not flashing, car seems to be running as normal. I did check gas cap, seems fine. Have started car one or two more times today and conducted some test in the manual, light still on. I do recall my 2006 Jeep doing same but in 2-3 days light went off.
something I should concern myself with or see if it magically goes away in 2-3 days. The car will probably get parked tonight and not move for ? 1.5-2 weeks.
Zachary
I would want to know the cause. Get a low cost code reader...or, go to AutoZone and ask them to read it for you.
B
bunkercowboy
Boerne, TX
it showed definition EVAP/ small leak / no flow condition
Prob cause?
Defective or loose fuel cap - checked it, seems fine
EVAP canister or hose cracked - not connected - not seeing any hoses off?
pure or vent solenoid defective ?
Vaccum leak at engine - autozone guy checked a few, saw nothing
Car seems to run fine?
jdeft1
Metropolis
Swap the fuel cap and make sure the seating surfaces are clean. I agree w/ Steve-Indy. Clear it and see if it comes back. Also, sometimes a purge valve leak only occurs in cold weather at first.... Other sources are: gas cap, fuel lines, vac. lines, as you know.
If it returns the system needs to be tested properly by a service tech. with the right tools. There are timed tests preformed by the cars computer, measuring vacuum decay etc... Small evap leaks can be a PIA!
My .02
B
bunkercowboy
Boerne, TX
to clear it i need to buy my own code reader i guess? The guy at autozone said he couldn't clear it
