Pedal adjustment switch broke
anton28
My pedal adjustment switch broke. I guess it s a common problem. I remember seeing somewhere a fix for this, a part of some sort. Cant seem to locate it.
Timnineside
West Michigan
Its physically broken, or not working? There is a common fuse problem with these. And to Smog Dog, you have a date on the new ride yet!!!!!???!?!?!
-Tim
Viper X
Mine fell apart. Switch worked OK but mounting plastic studs broke. I installed some new screws into the plastic housing and it works OK now. That plastic part is very spendy.
Dan
A
anton28
It fell apart. The switch works, but the housing fell apart.
steve911
Cottage Grove, Wi.
Yea, both of my cars broke also. I got mine from SnakeOyl as they were an exact match of the originals. Made of a much better material than the others.
Save your screws though, as those tri lobe screws from Chrysler are almost $6.00 a piece and weren't even available when my housings broke and I couldnt find them on the 'net.
Mclarenalii
