Raise seats
vincy
Baltimore, MD
Is there a kit to raise the seats, especially the drivers seat? Or instructions on what to make and how to do it?
The car always felt big to me. Now I realized that I was sitting too low and had a poor view of the right fender. Sitting on towels makes the visibility better. I'm average height so I'm surprised others haven't commented on this.
Sitting on something is not the best solution because it moves your torso into the bolsters.
Joseph Houss
NJ USA
JonB?
There might be a simple solution to this. Can he add spacers below the rails?
Viper X
What is "average height"?
My wife is 5' 7" and prefers to drive her car with the seat lowered 1-inch.
I'll bet with more seat time, you will too.
Dan
J&R3xV10
Las Vegas
I would also ask about your height, I have a friend that is 5'4" and doesn't sit on anything and is fine driving her mamba
V
vincy
Baltimore, MD
I'm not a midget, about 5 10. Its a puzzle to me why the seat seems so low. My other car is a Porsche and I sit high, the fenders drop off, and visibility is good. The contrast between the cars may be why I feel too low in the viper. I'd still like to find a way to raise the seat.
J&R3xV10
Las Vegas
If the seats were any higher stock many of us couldn't fit. As it is I have a hard time with a helmet in the coupe.
ACRBruce
Socal
If you were 5'10, then someone must have lowered your seat without you knowing. I'm 5'11 and try to recline the seat as much as possible to avoid getting the 1" lowering kit and my old lady is 5'2 and she can see out just fine.
ShadowLight
Bizzare, this is the last seat related question I ever thought I would see. My 5' nothing GF has no problems either. I however want to lower it.
V
vincy
Baltimore, MD
That's what I'm thinking, it was lowered.
redtanrt10
Dana Point CA
Vincy, if its been lowered the seat track adjustment lever is totally different than stock, the 1" has a rod type lever, stock is a loop type lever that goes from side to side. Also you should be able to see a difference just looking at the seats. Mike
If it is, make sure you have your helmet on before you think you need it raised. I'm 5' 10" and i had to recline the seat to get comfortable. With the 1" kit its much better for me.
Paul Hawker
San Diego, Calif, USA
It is not difficult nor expensive to have a upholstery shop put an extra inch or so of padding in the stock seats. Should do the trick, and is easily reversable if you change your mind later.
ACRBruce
Socal
Vincy,
Maybe you can take a picture of the front of the seat with the adjustment lever, then we can tell if it has the 1" kit or not, or is your seat fixed?
If your seat has infact been lowered, you may be able to find a set of used rails cheap from this forum as many have gone w/ the 1" or 2" kit and have no use for the oem rails.
AZTVR
Chandler AZ
The other possibility is that the ratio of your torso versus leg length falls considerably outside the average, so that you are shorter than average when sitting.
Axial32
