Rear brake line problem
Knight Viper
Harford county MD
I tried installing my recently purchased CCW drag wheel package and the rims were hitting the brake line bolt on the rear caliper. I pulled the wheels back off to file down the bolt but when I reinstalled the lines (with the washer) they were leaking. I'm not sure if I distorted the aluminum block the bolt goes through or what I did but I need to get it fixed this week for next weekends 'crab feast and cruise'
I don't mind upgrading to stainless line or replacing the stock ones if this is my problem.
TIA, KV
Jim Wilson
Chandler, AZ, USA
I don't believe the washers are meant to be reused. Replace the washer and you should be fine. Most auto part stores carry them.
K
Knight Viper
Harford county MD
Thanks Jim, that would sure be an easy fix and one I could try today.
PS. I'm still loving thoes 3:55 gears even with the SC:2tu:
