Schulmann,
First, I agree with everyone here, definitely stick with DOT 4. Cars with ABS (’01 and newer Vipers) should only use DOT 4 or DOT 3 at the least. Due to the hydroscopic nature (compressability / sponginess brake feel) of the DOT 5 silicone fluid, it is not intended for use on cars with ABS. So which DOT 4 brands to use? This debate can arguably go on forever like a discussion about motor oil. I like Neo 610 because it the highest "dry" (no % moisture absorbed) boiling point, and a lot of track junkies swear by the Castrol SRF because it has the highest "wet" boiling point which leads to better consistency. Others like Motul RBF 600, Valvoline synthetic and so on...they’re all good. Unless you track your car often, it’s not critical to go with the top brands, but it’s much more important to flush out the old brake fluid when it gets dirty (dark tan to grayish color). Contaminants and moisture are corrosive and wreak havoc to the brake system, can seize master cylinders at the worst case scenario.
DOT 5 silicone brake fluid is better suited for older collector muscle cars and classics. The benefit of not absorbing moisture for prolonged storage time and consequently not having to change the fluid as often is more beneficial for these older cars that are occasional boulevard cruisers and show circuit cars that do not see spirited driving sessions. Generally, DOT 5 has the highest boiling point of all brake fluids. BUT the BIG DRAWBACK is a noticeably "SPONGY" pedal feel. Your brake pedal may travel twice the distance to get the same clamping force to the rotors. I’ve not seen a technical report of performance results with DOT 5, but I’m willing to bet it will increase stopping distances by some margin. That’s not good. Is it worth sacrificing some safety margin in an emergency brake situation? Of course not. In addition, any moisture globules will find it’s way downwards into the calipers and since water boils at 212 F (at sea level, even lower temp at higher elevations), you can get vapor lock very quickly. In addition X2, the two types of brake fluids are not compatible. I’ve also heard seals going out because when owners switched to DOT 5, they used some petroleum based solvent or alcohol to flush out the brake fluid...not good.
So flush your brake fluid often and stick with DOT 4. Even if you don’t drive it often, flush it because brake fluid will still absorb moisture over time. Flush it more often if you see track use. Remember, brake fluid is corrosive on paint, will eat paint. So be careful not to spill it if you’re a DIY’r and wipe off any excess and rinse off with water. Sorry for the long explanation, but you can see why the overwhelming majority will say stick with the DOT 4. Good luck.
