replacing t56 with tr6060
Trans Doc
Motor City
First what year is your Viper ?
If you have a pre-2000 you will need the trans modified for the speed sensor.
Other than the trans you’ll need the correct driveshaft slip yoke. The 6060 is .200” larger diameter. The trans crossmember will need to be modified for the mount stud. It is farther back on the 6060 approximately .5”.
