MtHam ACR
Searches on this topic leads to fastener corrosion and yellowing side sills. I have a different problem. . .
On my '01 ACR, I noticed last night the passenger side rocker panel cover (black trim part) is corroding from the inside, the paint is intact on the outside. This could be described as a paint bubble, but it's got the tell-tale rust 'crackle' when touched.
This rocker cover stretches from the hinge area under the door, turns, and runs up the door jamb. The spot is about 1.5" long by 3/4" wide by the back wheel in the bend where the panel cover curves up, and the spot is on the inboard side of the cover.
My guess is water is getting inside during washing and sitting right there in the corner with no way to escape. The plan is to take it to the dealer for replacement, I mean hey, the car only has ~2500 mi on it, but I have a couple of questions:
1. Is this common?
2. The cover is riveted on and attached to the rear fender at the door jamb. Seems like there is a chance of screwing something up in attaching the body panels. Any advice or "gotchas" to be aware of when disassemble- or re-assembling?
3. How is this prevented in the future (and no, not washing the car isn't an alternative
Thanks,
Eric
1. Is this common?
Thanks,
Eric
