Roe SC owners - need measurement for 8lb pulley
Mccarlin
Chicago, IL
Hey guys,
Finally picked up my car with the Roe setup :) Im wondering if roe sent me a 6.5lb pulley though as my boost gauge is only reading 6-6 1/2 lbs of boost in any gear.
Can someone measure the FACE of the pulley and tell me what your 8lb pulley is. My pulley measures 2 5/8 measuring the entire face.
Thanks!
mike
Shelby3
liu;g
The 8lb pulley is 2 5/8. Nothing close to 6 inches for a blower pulley.
M
Mccarlin
Chicago, IL
thanks! I typed that wrong, its 2 5/8 :)
Hmm, guess its time to check the boost gauge and see whats up, definatly sounds like an 8lb pulley.
jdoc7
Mike,
I'm experiencing the same exact thing. I thought something was a little fishy. I get 6 lbs in any gear max, with my 8lb pulley. Had it tuned by PBJ and they said they were getting 10-11. Not sure what's up and I haven't taken it back due to time constaints. I'll probably look into it next year. BTW, I'm using an Autometer electronic gauge with it's own MAP sensor.
M
Mccarlin
Chicago, IL
Mike,
So you think its the gauge as well? PBJ was seeing 10-11lbs of boost on the car?
Im taking my car down to PBJ in 2 weeks and i dont want to bring it down with any issues ya know.
Check your PM too :)
martyb
IL
Mike,
My car was over 12#'s when Joe tuned it, big time boost creep. This was with the 8# pulley.
martyb
M
Mccarlin
Chicago, IL
Mike,
martyb
Hopefully this is the case when i go down to PBJ. I knew i should of just gotten an wideband 02 and gauge instead of the boost gauge, its useless :)
Quantico, VA
It has to do with WHERE you are getting the MAP signal from. I think my hose (with Autometer gauge) was coming from the VEC2...it has to come right from the *** on the back of the driver side tube (no easier way to say it).
Or something like that! I know mine was off a bit.....then I re-routed it and it was good.
Joseph Dell
Atlanta, GA 30338
also, boost is a measure of backpressure. example: if you have a stock car w/ a pulley (size doesn't matter) and it gets 10lbs of boost on it and then you change ONLY the heads to higher flowing. you might now only see 8 lbs of boost. or 6. or 5 (w/ stryker heads)! Will the engine be more efficient at 5 lbs of boost than at 10? yup. will it make more power there? yup. is the natural instinct then to bump up the boost? yup. can you do that w/ a supercharger? yup, as long as you haven't hit max efficiency of the supercharger.
so an 8psi /8 lb pulley might mean 8 lbs. it might mean 10, and it might mean 6. it all depends on the efficiency of the vehicle.
end tangent. good luck!
JD
1TONY1
Dalton Ga. (Chatt. Tn.)
I don't think the tube's ever have boost on them. That is a vacuum "***" only.
Quantico, VA
But doesn't the MAP sensor that comes with the AutoMeter gauge simply (not to over-simplify) convert a given vacuum at that point....into displayed boost?
:confused: Its all PFM to me anyways!!!
M
Mccarlin
Chicago, IL
Thanks everyone for the comments. Im going to wait till i get down to PBJ so he can monitor the boost while tuning the Vec2 to see if its where the gauge is installed or what. :) then ill go from there.
