If you removed the shocks, or at least loosened the mounting bolts, the suspension needs to be compressed before tightening the shock bolts. This can be accomplished by jacking up each corner of the car with a jack under the lower A-arm/ball-joint.
If you had the whole car up in the air, and just set it down, you will need to drive it a little to settle it.
