ROE Super Charger system
J DAWG
MS
From his website.
"10 high flow Bosch fuel Injectors"
dunno what size though.
SUN RA KAT
Guest
42 is the answer to everything according to the Hitch Hiker's Guide to the Universe.
Go Roe! :2tu:
1TONY1
Dalton Ga. (Chatt. Tn.)
The injectors are top feed...your stockers are side feed. Anybody looking for a set of the 42lbers....I have a set for sale, they have also been flow checked.
PBJ
St. Louis, Missouri USA
Hey Sean,
I just installed one of your 8 pound kits the other day and I installed your optional injectors and they were (lime green tops)...I thought those were 42 lbs. Are they 50's ? I have used Steeda injectors before and their 42's are (lime green top) also...there are top feeds also. There are only so many people making the injectors...Bosch...etc. Is there a way to identify injectors by color as a rule of thumb ? Any help would be nice, it would be nice to know for sure by just looking.
Thanks,
Joe
Sean Roe
Jacksonville, FL
When talking about injector flow, you have to be sure and mention the operating pressure.
The standard injectors we supply in the kit have blue tops. They flowed 40 lb/hr at 55 psi. The lime green top injectors flowed 50 lb/hr at 55 psi. From memory, I think the graph showed the green tops at 44.5 lbs/hr at 43.5 psi.
Regards,
Sean
PS,
Joe, did you finish and drive the car with the bigger injectors and 8 psi pulley?
PBJ
Sean,
No, I just got the 70 mm T-bodies from the customer on Saturday. I should have it running on Monday. I sent Dave a couple of pictures after everything was painted...the car looks great. The kit is very nice and well put together...I hope it runs as good as it looks. Thanks for the killer product !!!
Later,
Joe
Gerald
Near Tampa Bay
ab, which setup did u go with ? I see you asking ?'s for both types.. Paxton and Roe.. Got anything installed yet?
c'mon man, spill the beans!
