I have been running 3.73 gears for a long time. I ran the calculator its close to the real deal but, after drag racing with that gear I am going to change to a 3.55 and see what the difference is. I think the 3.73 may be holding me back at the end as my tach is about 6k in the top of 4th. Open for any input here.
That is good info. What kind of times and trap speed?
Nice calculator here. Just plug in your tire OD, speed and final drive numbers and calculate to compare.
On a flat out percent basis, about 22% will be your change. 22% higher rpms.
SS %23670 with MM6 manual and GU6 3.42 gears
I have 3.73's and wish i went with 3.55's.
