Shift points, @ what RPM'S?
GimmeTheSpeed
Sacramento, Ca.
Shift points, @ what RPM\'S?
What do you guys usually shift at? 4500? the Rockers I have suggested not to take it > 5500.... But I've found droppin it at 4K was enough to move it pretty well..... and I can't wait to take it to SacRaceWay.... you guys think with my mods I might be able to snag anything in the 11's? Thanks!
Devin 97 Blue GTS
Miami, Florida
Re: Shift points, @ what RPM\'S?
GTS,
I shift @ 5200 under NA and 4200 under NOS, ran the viper on a Dyno and came out with the sift points.
Times 11.9 NA / 11.5 NOS (No grip from the pilots)
:laugh:
G
GimmeTheSpeed
Sacramento, Ca.
11.9 NA.... very encouraging... thanks.... so 5 grand is a pretty good point.... and man... if you can stick those tires on that NOS.... wooohooo! Thanks Devin.....
RedEnuf93
Lancaster, PA
Gen 1, Usually at 5000.
Dyno also lowered my shift points, I used to scream it to 6K...
FlyBryViper
Dallas-Republic of Texas
At Viper Days, it is recommended to shift at or before 5200. Keep in mind, some laps on some tracks are almost like 12 dyno pulls - every lap! I did 63 laps in one day at my last event, the Finals.
George Bryce
Americus, GA 31709
I shift mine at 6200.....I turn the shift light on at 6000.
When mine was stock I turned as far as I could in low. That made it the quickest. GB3
FE 065
MI
Make a couple of baseline runs shifting at a given RPM. Subtract your 60' time from your 1/8 mile (660') time to arrive at your 600' time.
Then change your shift points and see if your 600' time (660' - 60') gets better or worse. (You'll shift at least twice in that next 600' after you've gone the first 60'.)
Your shift point RPM will be the primary factor in a + or - change in your 600' time if you don't change anything else on the car while you're testing,
SNKEBIT
western wisc.
I shift mine when the little guy comes outta the glovebox and screams at me! :D :D
FE 065
MI
....sounds perverted to me!
SKY1960
