shiftlight for Vipers
Flyin Phil
Goffstown, NH, USA
If you've got an older Viper (mine is a '96), the shift light electronics needs to support a 5-cylinder configuration. Since there are two coil packs in my car, the tach sees a pulse for every 5 RPMS (I think) instead of the expected 10 for a V10. I tapped into the cable that plugs into the back of the tach for power, ground and trigger signal.
Anyway, for the older V10 like I have, I used the shift light from VCA member Mike Brunton at HighTechSpeed and set it to a 5-cylinder configuration. Works great!
Larry Macedo
Sanford, FL
The Viper is 2.5 pulses per revolution which will make a difference if using an Autometer product. The new products mentioned I'm not sure of, but would definitely ask up front or seek information before ordering.
ElDiablo Viper
Pomona, NY
I would get it from Mike Burton. His service is the best and he loves Vipers however he likes Gen III
http://hightechspeed.com/
SKY1960
