SRT Sun Visors Drooping at High Speeds ? No More
HiYoSilver
Lake Success,NY
Thanks to a modification: you can adjust visors to any tilt angle for better aerodynamics.
the NEW Visor Extender attaches to each sun visor to act as a bridge. It is now black to match the visors. Also an easy method to keep visors from dropping down at any speed is now possible. All accomplished without damage to your Viper. Attaches and detaches in seconds.
Call for info 888-4-NO-WIND
Y2K10 SRT#39
Olympia, WA, USA
Tell me how tying them together makes them less prone to droop at speed? I'm totally confused. Add area, and get less droop. Makes no sense to me. I need some explination here.
PBR
Western DAL
H
HiYoSilver
Lake Success,NY
Paul, I will post photos of the center Visor Bridge and the suspension that holds it and the regular sun visors up at any desired angle or tilt. It will hold at triple digit speeds without a problem.
No joke.
SylvanSRT
Sylvan Lake, MI, USA
more area more in the wind more drag if the stockers come down at 75-80 mph im guessing with more weight also they will come down sooner
H
HiYoSilver
Lake Success,NY
Actually Sylvan, I adjust the angle so the visors are nearly horizontal.
With this trim it minimizes drag, noise and turbulence.
Put your hand up between the visors over 70 and you will see what I mean.
As a racer, I would be willing to send you (or other racers) a demo to test on the road & track if you would like.
zen garage
Glenview Illinois
I hope you didnt spend millions of dollars on R&D for the Visor Bridge Thingy as for I fear it will not be well accepted. Most SRT folks are happy enough with their visors removed.
I would be more than happy to demo one for you and post my unbiased results in you like.
plumcrazy
ALL OVER
yeah i saw yesterday the effect this great product has on downforce in the SRT i was driving with. what a difference and his hair wasnt even blowing around.
i personally cant imgaine why anyone with a convertible would be complaining about wind and noise but it does help with downforce in a BIG way.
Paul Hawker
San Diego, Calif, USA
I like using Sun Visors on warm balmy nights. At low speeds I tilt them up high, and they force air into the cockpit, that sometimes gets warm. Especially handy when the interior is warm, and you want to blow out all the hot air.
There is a problem with tilting them up so much. When you get up to speed they flip down level. By joining them together a small triangle is formed and they should stay up in any position you choose. Might make the cockpit disturbance a bit less.
Krazy PSI
Any franchises available?
06 MERCEDES SLR
06 MERCEDES CL65
06 BRABUS ML 500
06 FLYING SPUR
06 CARRERA GT
05 MURCIELAGO
06 FORD GT
SRTRICKY
Canada
06 MERCEDES SLR
06 MERCEDES CL65
06 BRABUS ML 500
06 FLYING SPUR
06 CARRERA GT
05 MURCIELAGO
06 FORD GT
LMAO :D
