SS oil cooler lines
luc
Paso Robles CA
If you're talking about the 2 lines going to the oil cooler,
it doesn't matter, the oil cooler is not "directional" and you can reverse the in and out .
Luc.00GTS
T
texasviper
Dallas, TX
That's what I thought. It's just a two pass U-tube heat exchanger and the lines are the same diameter. Thanks for the info. I can see why they use braided SS hosing. The hoses had several badly wore spots.
T
texasviper
Dallas, TX
Some pix and tricks of installing SS lines.
xeng yang
