I had this happen to me too and I found a fix last year on this forum. There is a simple fix.
The loss of cool air when accelerating is a loss of vacuum to a one-way valve behind the AC controls in the dash. If I remember correctly this valve keeps a vent closed. But when as you accelerate this causes a vacuum increase . The valve is too small or gets old to hold vacuum to keep the vent shut. An easy fix was to supplement the valve with another valve, which is a 5 sec fix.
There is a vacuum line located on the rear of the valve cover on the passenger side. I pulled the vacuum line and attached one side of the valve to the existing line and the other side to a short piece of 1/16 rubber tubing into the vacuum port. Problem fixed. Cold air all the time now. The proper way to fix this would probably be to replace the valve behind the AC controls but this is much easier and faster.
I don’t know if this is a permanent solution but I’ve had mine on since last summer and it still blows cold air on acceleration.
Here are the parts I got from McMaster-Carr
http://www.mcmaster.com/
Part # 47245K26
Diaphragm Check Valve, Nylon Body/Fluorosilicone Diaphragm, 3/16" Barb
Part# 51135K172
Silicone Rubber Tubing, Firm, 3/16" Id, 5/16" Od, 1/16" Wall, Black
