Stock Knob Shifter
GR8SNAKE
Canton, GA
HELP, PLEASE! I also looked under how to's on this. I'm trying to remove my stock shifter knob. Replacing it with a new MGW knob. Been trying to get the lock nut loosen ( wd40 don't work), but with no luck. Just do not want to break the shifter. Is there a trick to getting the lock bolt loose?
David B
G
GR8SNAKE
Canton, GA
The stock lock nut is on there real tight. Just turn the lock nut hard clockwise with a 9mm amd whole the shifter with a 7mm.
ctrengine
