STOP RUNNING WHEN HOT
loquito
QUEBEC/CANADA
I have a terrible problem whit a 1993 r/t 10 the problem is the engine stop running when he start to be hot and I have to turn the swihct of for a few second to restart the engine if a t'hont wait 10 second and try to start the engine he will never start
Ulysses
San Diego, CA. USA
Re: nead expert diagnostic
I'm sorry, but I am having trouble understanding what is the problem.
Are you saying that it shuts down when the engine warms up? Hard to start after it shuts down?
Or
Engine is over heating and it shuts down?
dblankenbaker
Scottsdale, AZ
I saw this at Gingerman once with Gen-1 Viper that was low on coolant. The car quit running. The tank with the radiator cap was dry! We added coolant and everything was fine.
L
loquito
QUEBEC/CANADA
i want to say thet my engine when is warm shout off and I HAVE TO PUT THE IGNITION OF FOR MAYBE 10 second to restart if a d'ont wait 10 second the engine will turn buts never starts sorry for my writting I AM FRENCH I HOPES YOU COULD HELP ME Ichange map sensor,camshaft sensor,crankshaft,heater coulant engine :confused:
SingleMalt
Loguito, en Francais si'l vous plait?
Merci.
SingleMalt
Vérifier:
1) Batterie
2) Pression d'carburant; est possible su pompe sont fin :(
Mike
tommygun
WE HAD THE SAME PROBLEM ON A 94 RT/10 AND IT TURNED OUT TO BE AS I RECALL TO SENSOR GROUND WIRE FOR THE SPEED SENSOR ON THE TRANSMISSION. IF YOU FOLLOW THE WIRES BACK FROM THE CONNECTOR ON THE SENSOR YOU MAY FOUND IT HAS EITHER BEEN MELTED TOGETHER WITH THE OTHER WIRES, CAUSING SHORT TO GROUND IN HEAT OR IT MAY HAVE RUBBED THROUGH AND BE CONTACTING THE TRANS OR FRAME. I CAN UNDERSTAND LOQUITO BECAUSE I AM USED TO INTERPERETING MY TECHS. HIS ENGLISH IS ONLY SLIGHTLY BETTER.
zeeshan_k24
