street legal 97 gts runs 10.51 @ 135
R
RENTME
My 60' time were all around 1.60 but i was running a weak stock clutch this year i have changed the clutch so it should be in the high 1.5s
Thanks Tom
R
RENTME
The RWHP without the juice is around 675
Thanks Tom
utahviper
Utah
Not a bad run. Love the nitrous shooting out of the hood.
I found that the best psi for the bfg's is 17-18psi and slip the clutch out of the hole for 1.5x 60 footers.
Are you running water methanol? I would be curious to see your time slip.
R
RENTME
Thanks guys, no water **** but thinking about it this year, how much HP should it add
Tom
R
RENTME
I am running 3.55's and i have to shift to 5th gear when running the NOS
Steve Kleva
AZ, USA
I had to shift into 5th when I was on a 26 tall tire. I picked up 4 tenths going to a 28 tall tire.
R
RENTME
STEVE DID RUNNING A 28" TIRE KEEP YOU FROM HAVING TO SHIFT INTO FIFTH GEAR
Steve Kleva
AZ, USA
yes. I was able to get about 130 in 4th with the 26" tire. Went to the 28" and was able to hit around 140ish.
GTSnake
Motor City
Your numbers are almost exactly like mine.
My 10.58 @ 139mph run was a 1.66 60' with BFG DR. My HP numbers are 690RWHP without juice. The only difference is I have a 10lb pulley instead of 8lb.
I guess the '97 GTS' are pretty consistent. :2tu:
R
RENTME
GTSNAKE SOUNDS LIKE AWSOME #S IS THAT WITHOUT RUNNING NOS
RENTME
FE 065
MI
What's the wheel/tire combo that gets you a 28" slick..? Guess I should know, but no clue..
:bonker:
GTSnake
Motor City
RENTME
Yup, no NOS. I tried turning on the bottle but later found that the wiring was installed wrong so the NOS never kicked in. I've since rewired it so the next time out I'll try it with an extra 80hp shot.
Casey
Valparaiso, IN.
Damn Tom! That's some POWER!!
You aren't going to hit that SHOT out of the hole! :D
R
RENTME
yes this year I am going to a racing clutch , 15 lb pully , water/**** and a two or three stage nos kit with a 50 shot in first gear (i Need a good tuner that is set up for vipers do you know any close to mass )
SKY1960
