Successive exhaust mods and lessons learned.
Daffy Duck Viper
Austin, TX. USA.
Okay, I'm trying to visualize all these mod combos, but now I'm confused.
I thought "cat" was short for catalytic converter.
So then how can you have "Borla cat back" and "factory cats" on at the same time?
Someone please explain this. Thanks.
GR8_ASP
cat back is everything "after" the cat, not including the catalyst itself.
Dixter
Plano, Texas USA
Borla cat back = components behind the cat ( does not include cat )
Factory cat = cat converter ( does not include cat back components )
Borla cat back and factory cat = cat and all components out back of car
D
Daffy Duck Viper
Austin, TX. USA.
Okay. Got it. Thank you so much. My brain doesn't hurt now. *chuckle*
KenH
Portland, OR, USA
Great info,
Now how about throwing on a set of gears so that we can put that question of whether lower gears measure lower HP on the dyno thing to rest once and for all :D
The car was moving more volume be not increasing fuel. I have been forced to use a VEC1 to keep my A/F ratio stable.
Hope this helps someone. ;)
Eric Jordan
White and Blue 96 RT/10
Eric,
I would suppose that this is because the engine is in open loop for most of the rpm range on a dyno pull. It is running off the base tuning map and not able to adjust pulse width or timing to suit the better VE.
That's really great info. Thanks for posting your results.
