The HOT air returns....A/C issues
fastandloud
Frisco, Texas
It started last summer when I had to replace both the resistor and blower motor...now the dreaded intermittent blowing cold then hot air has returned. I've put guages on the car and everything looks good. The compressor seems to function fine some days then other days it cycles off and on every few seconds. Is the compressor shot or is there anything else I can look at before a trip to the dealership?? A trip without warranty now btw..
Scott
JonB
Legacy\Supporting Vendor
Columbia River Gorge
When asking technical questions about a Viper
THE
YEAR
MATTERS
It might be as simple as adding an auxilaiary vacuum canister as many sedans/SUVs have. Cheap.
bluesrt
u may have a blockage- do u have a good sweat back on the low side line at idle?
F
fastandloud
Frisco, Texas
Come on JonB..you can see the ride. Gen III good sir...2006 slate, the fastest btw..
VIPER R
Try giving it a good evacuation and recharge, you may have air and moisture freezing up.
Brian R
