Thread size
Chris1
Drums, PA
Hi everyone: Does anyone know the size of the threads that the little 2-3 inch bolt that holds the top rear of the sliding side curtain(s) to the top rear of the door panel on a 1996 RT/10 are? The threads that the bolt screws into seems to be messed up, as I can't get the bolt to screw in properly. It's not a big deal, however if it's just a matter of running a simple tap to cleanup the threads, then I'll give it a whirl. The threads on the actual bolt seem to be OK.........
Thanks, Chris.
Tom F&L GoR
Wappingers Falls
Looks like 1/4-20. If you can, remove half the threads (kind of like racing studs for wheels.) You don't need nearly as many as on the screw screw screw...
C
Chris1
Drums, PA
Thanks for the info; I'll give it a whirl; it's not a big deal to have the screw attached, however I like to have everything as correct as possible......
zeeshan_k24
