TORCO Unleaded Accelerator Octane Booster... How many people have used this stuff??
eabrillon1978
Albuquerque, NM
Trying to find an alternative to buying race fuel and mixing it with 91. I've been reading some of the forums about this stuff. If you read the link, you'll see that they did a lab test with this stuff. Mixing 10 gallons of 91 and a quart of the octane booster gave them 96.5 octane. It's an old post from corvette forum.
http://forums.corvetteforum.com/c5-...o-octane-accelerator-i-am-now-a-believer.html
Purchased a can of this a couple of days ago from Yearwood. Just curious if anyone has tried this out.
Lemme here some of your thoughts on this stuff and what else are you using???
Do you think this stuff will mess up your motor?
How many of you mix in E-85? What ratio are you using?
Dom426h
DE
What year is your Viper?,
What mods do u have?,
Are you running a stock tune?
E
eabrillon1978
Albuquerque, NM
Re: TORCO Unleaded Accelerator Octane Booster... How many people have used this stuff
98 GTS
Roe supercharger at 10lbs
Greg Good ported heads with 2.02/1.60 valves
Macedo Motorsports air intake
Accufab 70mm throttle bodies
Bored .022 over
Custom Solid Roller Cam
T&D's
Methanol Inject
53lbs injectors
B&B Headers
No Cats
B&B Exhaust
Vec 3
Not running the stock tune
Dom426h
DE
GTSnake
Motor City
Try toluene. There were some threads about using it to boost octane a while back.
redtanrt10
Dana Point CA
Here's some info from the 4th link Dom426 posted. Dan at DC Performance recommended 100 mix vs. Torco, here's a post from one of the SoCal guys
Not crazy about Torco as a fuel additive as it leaves reddish brown deposits on your spark plugs, valves and in the combustion chamber.
Better to mix your 93 with a quality 100 octane pump gas.
DC Performance can provide you with input on this subject.
