VEC 1 Tunning Tips. How To? Thanks
Dimitrios
Queens, New York
just got roller rockers and VEC1 Installed by the ole mighty Tator. What setting do you guys use on your VEC1's. I tried -4 +8 and i was getting an idle at 1750rpms and didnt feel any difference. any suggestions? thanks
PRVT JET
streamwood, il usa
I think you have it backwards, low should be+, high should be -. On the low side my car likes between +8-12, on the high side it like -14-20. Hope that helps, Also follow roes direction on setting the vec1. After you pick the perfect settings, return the dials to 0-0. While parked at idle, move the knob towards your ideal settings two at a time and after each move hit the gas full throttle for a second. continue to do both settings high and low. hope this helps.
DrumrBoy
GA
Is there anyone that has the instructions for setting the VEC1 that they could email me or fax me.
I think I may have what Sean sent me, if I still do I'll e-mail you in 5 min.
DrumrBoy
GA
WV,
I have the files you want but your address either is an old one or your mailbox is full. The zipped files just bounce back. If you want the manual, let me know how to reach you electronically.
This address is the one that bounced <[email protected]>
HOdbleFman
Hurricane, WV
DrumrBoy,
I apologize about the email. I got rid of aol last week and forgot to change my email address on the board. I appreciate you taking the time to send those to me. Send them to [email protected].
D
Dimitrios
Queens, New York
k just checked the setting and it was backwards just like you guys said. would this make the car run slugish. it felt like i was driving a V8 or something and had no power at all. I will set it on right ##'s and will let you know how it goes. thanks for all your help.
00prowler
Vernon CT USA
The vec1 gives you around 10 to 15 RWHP. If you can feel a difference when you set it properly it will only be in your mind. The dyno is where it shows your gains and proper settings as fact, but in conjunction with your rockers, tubes, filters exhaust, etc. all combined is where the speed gains lye...00PROWLER
D
Dimitrios
Queens, New York
thanks for all your help again guys. i set it the right way and the car sounds alot better and really moves now. the AF meter keeps bouncin back and forth to red and blue. is this normal?
PRVT JET
streamwood, il usa
The back and forth is normal, when ever it's under load it will give a reading. When you had it on +8 on the high, you were dumping a lot of fuel in the motor. How long didi you drive it like that? you may need to change your plugs, they could be fouled.
D
Dimitrios
Queens, New York
drove it for about 30 miles before setting back to normal 0-0 settings.
PRVT JET
streamwood, il usa
That shouldn't be too bad, I was also told that once in a while you do have to go back to 0-0. Then set the vec1 to your specific settings. I also heard that the stock computer tries to override the vec1, that's why you have to reset once in a while.
