VEC3 keeps frying!!! HELP!
2001 GTS
Charlotte, NC
I've had my VEC3 rebuilt by Sean twice now. Both times the slave board fried.
Both times the car ran great for 2 weeks then out of nowhere #2 and now #4 cylinder stop opening the injector. I just don't understand how last Tuesday the car ran the best it has ever ran, then the next day I fire it up, take it out then 5 miles down the road it starts missing and backfiring.
Now it looks like it has fried AGAIN! The VEC is installed right, I've been over it ten times now.
I'm starting to wonder if a stock wiring harness was hit when the motor was put back in, but if it was then why would it run great for 2 weeks????
Any help would be greatly apprecited!
I'm going to try Bobby's Split-sec next week, but I don't want to fry that too.
Steve
id guess its a wiring harness somewhere thats doing it. maybe have another set of eyes go thru it for ya...
BOTTLEFED
Pocatello,ID
yeah, sounds like something in the wiring harness - either in the stock injector harness or the VEC harness going to the injectors
you may have a break in the wires where they are shorting out and taking out the VEC
also check the injector connectors
2001 GTS
Charlotte, NC
Thats what I am going to do Monday! I might be in a daze from looking at it so much...haha
I'm hoping it is just a break somewhere. I already changed the injector connectors with the MSD ones after the last time.
You can always use an SCT with the proracer package to do the tuning yourself, or working with a tuner and dyno.
Feel free to call if you have any questions on the SCT.
Michael
BritoSpeed - Need Has Nothing To Do With It - Home
Might have to do that, thanks Michael.
GTSnake
Motor City
I'm going with a short in a wire somewhere. Maybe something got pinched or cut and is shorting intermittently.
Joseph Dell
Atlanta, GA 30338
Injector clips were recently replaced... And the problem is always on the same side of the motor. Definitely sounds like a short, but what would make the VEC fry but not a stock PCM?
SCT is probably the way to go... At least it will mask the problem for now and get you on the road!
dansauto
gillett, pa, usa
i had a problem with mine, I was unplugging the injector harness to find a plugged injector and that caused the vec to short out, dont unplug your injectors while the car is running!
BOTTLEFED
Pocatello,ID
Although the injector clips have been replaced, the harness itself could have a short inside before the clips
the reason the VEC is getting fried is because it is in series of the injector wiring
it is burning up the VEC before anything happens to the PCM
Joseph Dell
Atlanta, GA 30338
So are you speculating that PCMs would fry if the VEC wasn't there?
Interesting...
Jack B
NE Ohio
Sounds like the VEC does not have *open load protection*, in which case Steve should be looking for a break in a wire also.
To expand a bit, most power supplies or dc converters regulate the the voltage output and are not load dependent. Some circuits are load dependent to keep the voltage in a specific operating range, therefore the removal (an open circuit) creates an overvoltage and components can suffer. This would not be a good practice (design) in a circuit that has to add a very precise level of voltage.It would be interesting to know if an open injector can create this issue. It is almost certain that the PCM itself has some type of current limit circuit in the injector output.
BOTTLEFED
Pocatello,ID
I would have to find the thread, but I remember an owner saying that he fried his PCM when he disconnected an injector while the car was running...
so this could be the answer to the load protection question
2001 GTS
Charlotte, NC
So could a bad or loose injector connector cause it all?
BOTTLEFED
Pocatello,ID
I think it would have to be a pretty bad connection where no connection is being made at all
if you think about it, it is taking 2 weeks for your VEC to fry, so it must take a while for it to finally burn it up
I just saw that thread the other day
I'll try to find it again
ctrengine
